Just did 351 swap
stefanniels
Hello.
I just put a 351 windsor in my 77 bronco and when i drove it today the c4 tranny wont go in to 3-rd.
There is enough fluid in it, so i don
S
stefanniels
Has nobody got any good ideas for me.
Could this be caused by the fluid having hard time getting trough the cooling system(radiator and extra cooler)??
I
Did you disconnect the shift linkage when you did the engine swap. If so, did you go thru the linkage adjustment proceedure when you rehooked it up?
Has nobody got any good ideas for me.Stefan.
26985[/snapback]
We gave you two...
1. Maybe the shift linkage needs to be re-adjusted. May not be dropping into the 3rd gear indent.
2.Did you disconnect the shift linkage when you did the engine swap. If so, did you go thru the linkage adjustment proceedure when you rehooked it up?
"Could this be caused by the fluid having hard time getting trough the cooling system(radiator and extra cooler)??"
---Was this a problem prior..? you said it was fine B/4 the eng. swap. ---
Sewerrat
this happened to me on a chevy but double check that your vacuum hose from your engine to transmission modulator is not leaking. also make sure your engine is producing enough vacuum at idle.
fordtruckman
27116[/snapback]
yes checkl the vacum lines from engine to modulator. i thought changing all the fuild and filter at first but that does sound like a modulator problem.
S
stefanniels
Yeah but if were a vacum problem should it shift from 1st to 2nd???
Stefan
fordtruckman
Stefan
27136[/snapback]
i really don't remember what happens when the modulator isn't working properly. but i do know it won't shift in to one of the gears. i would check that stuff before you dismiss it. or don't check it.
S
stefanniels
Could the electricity that goes down the firewall down to the automatic have anything to do with this??
Stefan
Sandoval_broncosauria
