Junction Block location?
BronBronBronco
Santa Clarita,CA
Good morning all.
I am trying to locate the junction block location were the voltage regulator, amp meter,fuse panel,ignition switch,lighting switch come together. I looked on the outer firewall and also under the dash and did not see it.
I attached a schematic that shows this component which I am having a hard time locating. Any and all help is appreciated.
oleguy74
when posting for help remember to put year of your bronco as changes were made to some things over the production years.
BronBronBronco
Santa Clarita,CA
Thanks BullyBob & oleguy74. The Bronco is 1969 with a 302.
I think you are right BullyBob as that is more of a block than it is a connector.
I will pull it apart and look for corrosion or a bad fit.
Thanks!
