I replaced my fuel filter this weekend. The thing was so clogged I could barely blow through it. That took care of the sputtering problem I had. Now there's a new problem.
When I crank the Bronco it will idle strangely. The RPMs go up to 1500, then back to about 500, and back and forth. Sometimes it cuts off. If I tap the gas and get the RPMs up to about 2000 or so it will drop back to 1000 and idle steadily there after that. Any ideas what I should check out first?
Brad
Brad
