Krafty
so just the other day my truck (89 f-150 302 efi 213000 km's) ((100 000 ish miles)) went from running tip top to stalling almost every time I stop at an intersection. Can see oil smoke when on the highway with the pedal to the floor. tops out at about 63 mph, runs very rough at times when on the highway. when idling it fluctuates from normal to almost dead constantly, even when in park or neutral the engine will bog when revving. can see oil residue on the ground beside exhaust after sitting while running for a few minutes. last time I changed my oil after 5000 km's it was very much broke down and had very little in it, maybe 3 liters.
coolant level is fine and no visible leakage on the exterior of the engine can be seen.
oh and when I disconnect something on the vacuum ( ie brake booster) it idles perfectly fine, maybe a bit high, but when I reconnect it the idle drops and dies everytime.
im thinking piston rings... what do you guys think??
