hood alignment
bigtrux
Murrieta,CA
i have a 93 bronco i just bought and my hood sticks out further on the driver side than on the passenger side is there anyway to adjust it or am i just going to have to by a new bracket ... and hope that fixes it
Shadow_D
Schenectady, NY
NO!
There are bolts that you need to loosen enough to hold the hood in place but will allow you to use some force to align/move the hood
also, look at the shims under hinge bracket; ck for loose bolts & the hood stoppers on top of the radiator support (rubber bumpers)
grande_guerre
grande mondiale
originally-Alaska, temporarily-Arizona
on the topic of body panel alignment, how do you go about easily aligning a driver's door??? i have to push down on the handle to close the door, and wiped out a brand new door jamb bolt. i also got in an accident that created the problem. there's a dent up top, would that have to be pounded out???
kyleh01
