HEy wasssup
jawslwood
Crate motor 5 years ago , tranny rebuilt shortly after. logged on to maybe get some tech advice cuz i need a new cat. How direct fit are these direct fits they sell?
yo!
Here is the usual disclaimer for a universal cat;
"UNIVERSAL Catalytic Converter, Oval Body Type, One AIR Tube, No Oxygen Sensor Port, 2.50" Inlet, 3" Outlet, 14" Body, 18" Overall Length, May Require Cutting And/Or Welding. To comply with pollution laws, automakers have made many refinements to car engines and fuel systems.
Price: $89.17"
http://www.racepages.com/catalytic/ford/bronco.html
1987 - 1990
Notes: UNIVERSAL Catalytic Converter, Oval Body Type, One AIR Tube, No Oxygen Sensor Port, 2.50" Inlet, 3" Outlet, 14" Body, 18" Overall Length, May Require Cutting And/Or Welding
Engine: 5.0L, 8 Cylinder
Brand: Eastern
SKU: #70637
Price: 89.17
you can buy the O2 **** & air tube **** anywhere and have them and the cat welded it, adding to cost of course, but not as much $ as for a direct fit cat.
"1987 - 1990
Brand: Eastern
SKU: #70637
Price: 89.17 "
http://www.ecatalyticconverter.com/ford-br...-converter.html
Welcome to the Zone > . I have a direct fit system on my truck and it works just fine. The cat was different then the original, Original was two seperate cats while the direct fit combined both functions into one cat like all modern ones do. They gave me an extension pipe for the air inject which took a little playing around with but once together everything was just fine. Some systems provide a high temp rubber hose for the extension.
Post some pictures of your truck.
wtfdissux
Buffalo, NY
i agree with seabronc they are cake to install and work better than O.E. and they dont "require cutting or welding to install " when time is money and the direct fit is around 250 and is just that direct fit and your y pipe and every thin from manifold to muffler are new without playing erector set i call it a good idea by the way meisk just want to let you know that i think your home page is amoung the best resource sites out there just wish i could put the whole thing on a disk for the times i want to look something up and i am not at home
wtfdissux,
thanks man
My son just wrote a new proggie for the site; we're going to a new server, URL, host, etc. soon; the site wil be more relational database type than the current one.
And it can be ezier to copy with Hot Links in-place
You could copy the entire current site now by copying each section (EDIT, Select All, COPY) & then pasting them into an e mail to yourself;
the Links will work from your received copy.
wtfdissux
Buffalo, NY
on a side note i have seen headers that list both the 5.0 and 5.8 for the application firstly are they the same in that regard and if so would the same be for stock manifolds and if yes anyone know what the differences(size/length to cut and add)on the y pipe not crazy about the idea but may be cheaper than replacing my y pipe and manifold (broken stud and bad ****** = loud truck and bad running)
wtfdissux,
thanks man
and your saying this to someone that just figured out the quote reply feature......lol I will wait till its running again not patiently but will wait all the same like it the way it is can navigate in an almost unconscious state and your gonna make it easier good deal btw think they can add spell check on this site so i dont have to use cut and paste from aol mail in my posts
Sandoval_broncosauria
