Help identify PS box
PGreenlawMD
1967 Ford bronco aquired a year ago working on a full rebuild
It arrived with power steering that was noted to be a delphi PS box with an older ford PS pump
Now the pump is leaking and grinding and replacing with a saginaw HD pump
Ordered new PS hoses specific for the Saginaw/Delphi combination from JBG and they look great
Imagine my surprise when I removed the old PS hoses from the PS box and they are the female inverted flare fitting and the JBG hoses do not fit!
Is this a Delphi PS box? Did the delphi box come with the female inverted flare fitting? Any easy fix for this problem?
You're quite welcome..!
Other options are local shops like "House of Hose"  can custom make hoses with the correct fittings
& they're quite reasonable.
fred tyler
