help!! body lift question
bluefordcat
SOUTH DAKOTA
:blush: think of installing a 2-3 inch body lift.. Will I have to adjust bumpers & fan shrould or will it lift ok & look good?
after body lift next would be a 4"suspension or 6" any comments what would be best? I'm thinking of runnig 15-33x10
89Bronco58
Jersey
you will have to notch out the frame or the bumper in the front after a body lift, the rear bumper will need to be moved up too most likely, the fan shroud will go up with the radiator and shouldnt be a problem..mine wasnt, and your going to run a 2-3 inch body and then a 6 inch suspension and only run 33's?
Coastersfwb
