headers
Its a pretty basic install. The hardest part will be removing the old exhaust manifolds. Take your time, if you break a bolt off in the head your in deep ****. Clean the gasket surface very good and thats that. If you read the directions they will usually give you a tip or two that will save you headaches. Like whether they should go in from the bottom or top. Whether you need to remove driveshaft or not or if the dipstick has to be removed.
