Gas Tank question Too
Auggie
Saint Augustine, FL
Quick question for the Bronco Brainiacs.  I have a 23 gallon tank in rear of vehicle.....front tank was removed.  There are three outlets in the rear...fill tube, overflow tube, and another that I assume is a vent of some sort.  The problem I am having is when the tank is full since there is only a short (3") piece of fuel hose on this last outlet gas pours out of it. Especially when turning a corner!!! yikes!!!  It is the same gas (23 gal) tank that is available on JBG. All ideas are welcome.
It's not likely it's a "vent" ---- The gas cap does the venting.
It's more likely it's a "return line" ****** for the newer rigs that had vapor recovery.  (smog system)
-------- EFI systems use this ****** as a fuel return line. ------
Plug it & check to see if you have the proper vented cap.   :-B
Auggie
Auggie
Saint Augustine, FL
Will do!  Once again information that is not available anywhere else.
And yes, cap is a vented one.  :)>-
Gary wilder
