Gas In Oil
Bronc Oh
I have a 93 5.8 that won't start , there in raw gas in the plennum and all cyl. but # 8 is worse. if you clean plugs and dis connect fuel pump it will run til it runs out of fuel , but with pump on it will flood instantly . Injectors are good. any ideas. Thanks
azrockrat
kingman az
replace your fuel pressure reguator that is located on the back of the drivers side of the engine. it is round and has a triangle on the bottom where it attaches tot eh rail. that should be the problem
Raven
yea the fuel pressure regulator just had to replace mine I was running at 80 psi in the fuel system when should be 28-45 psi ..
Bronc Oh
Thank for the info . that was the problem it's running great now.
Gary wilder
