Fuelling probs...
monza
San Francisco
hi guys,
75 EB, 351, Holley 650cfm 4 bbl, Holley mech pump.
I have intermittent starting probs.
the spark is no problem - she turns over furiously.
I have a small glass fuel filter inline to the carb - so i can see fuel line content.
On some days the filter is full - mostly its half full - but sometimes its dead empty...
obv when its empty it takes time for the fuel to come thru and fire up.
it didnt used to be like this - she has always fired first time.
When she fires and i watch the fuel - i can se the pump kick in and fuel sputter into the filter AFTER she has been running for a minute or so.... which means when there is no fuel in the line I am just turning, and turning and turning until the fuel sputters thru...
I am not experienced in this stuff, but shouldnt there be some kind of vacuum effect which keeps the fuel line charged ? so the pump isnt dragging it from the tank every time ??
As far as i can assess the whole fuel line is empty - she starts on residual fuel (wherever that is) - then the pump has to drag new fuel all the way from the tank... but when i have no residual fuel i have a problem...
and i am frequently experiencing no residual fuel...
any help would be great.
thx dudes, Monza.
You may have a bad check valve in the fuel pump.
One "shade-tree" test is to ***** by mouth, into the fuel line (at the fuel filter area, or carb, whichever is easiest to get to) & see if air passes back to tank.
Also, make sure your accel. pump is working, by looking down the carb air horn & moving the accelerator. (Eng. & key off of course) This is a starting prob. 75% of the time.
monza
monza
San Francisco
1. Okay - if i can blow air to tank do ineed to replace fuel pump - or just a valve ?
and what does the check valve do.
2. Bit more help here... 'carb air horn' - is that just straight down into the carb with air filter off ??
I take it I can adjust throttle at carb - no need to use pedal in cab.
How do i know if the pump is working - wht am i looking for ?
thx again,
Monza.
"---- Okay - if i can blow air to tank do i need to replace fuel pump - or just a valve ?-----"
PUMP....check valve is supposed to hold pressure in the line after the pump.
"----carb air horn' - is that just straight down into the carb with air filter off ---"
YEP
"----How do i know if the pump is working. what am i looking for ?---"
You should see a stream of fuel shooting down into the depths of the carb.
Staff online
figjeti
