fuel sending units
Bcrump5252
has anyone replaced them, and if so can you tell me where I can find a detailed explanation.
thanks for the help, hopefully my 71 will be ready for the trails by spring
Broncoholics
Broncoholics
Washington State
Pull the tank, use a screwdriver and hammer to unscrew the large ring. Pull out the sending unit/ pick up tube, replace and use some vasoline on the rubber gasket so when reinstalling it doesn't pinch, twist or cut the gasket.
combstj
Tampa, Florida
30194[/snapback]
I had a leak in my tank. I replaced the O-ring, and it still leaks. Any recommendation? My next step was to use silicon gel.
figjeti
