Frustrated(I just wanna drive my Bronco)
bigtrux
Murrieta,CA
:(( I got a 93 bronco with 351w i just replaced the motor i used the same coil,dist, injectors off the old engine which started no problem always crackned over. it was just shot. now i got a new block plugs,wires, battery and doesn't seem to want to start. i know it has fuel at the fuel rail. And i know i attached every connection i was took my time to ensure everything was back together. any ideas or similar problems i'd apreeciate the help. meanwhile i'll trouble shoot it when i get off work thanks fer any advice . kevin
bigtrux
bigtrux
Murrieta,CA
It cranks just no start i think i have to check spark it started pouring last night so i couldn't trouble shoot all. i'm going to check spark and recheck TDC AND DITRIBUTOR LINEUP TONIGHT..
Yeah, I was going to suggest checking the dizzy to be sure you're at TDC on no. 1, and not 180 degress off. Another thing to be sure of is that the engine is grounded properly to the body and frame. Simple things first, it helps to have a volt meter and check for power at the coil and dizzy. IF those have spark and you have fuel, the motor should fire. IF the timing is way off, you can bend valves and do some damage. Hope it's just a simple ground or unplugged wire. Good Luck, JSM84
wtfdissux
Buffalo, NY
I know your frustrated but thaught you might appeciate the humer to this it was given to me the first time I had a similiar exp.
bigtrux
bigtrux
Murrieta,CA
I LOVE THE CHART ***. I AIN'T NEVER SAYING WHAT I DID BUT TIMING WAS OFF NEEDLESS TO SAY .. BUT IT'S RUNNING NOW.. JUST NOTE TO ALL WHEN IT'S GEETING LATE AND YOUR TIRED AND OR BEEN DRINKING LEAVE THEW SHIT FOR THE NEXT DAY.....
wtfdissux
Buffalo, NY
yeah got that after rebuiling the shop's tow truck engine in what I think was record time 14hrs. boy was it nice before fuel injection but long story short mixed the firing orderup and was 180 out
Coastersfwb
