Front Spindle
Mcflea
My 1995 was smacked in the front end. i bought new rotor bearing.....the works... all new
I noticed that the drive shaft spline that fits through the spindle was not centered. I bought a junkyard spindle (thinking the original must be bent) and after 3 hours of labor, I finally installed the new spindle. It is now more out of alighn than it was with the original spindle?? is is possible that the shaft spline is bent also or is there a trick to alighning it during installation. Thanks, Mcflea
The hub assembly alignes the axle. The axle floats freely in the spindle. Make sure you put the retaining clips back in and your all set
Coastersfwb
