I am new to this but here goes. I have a 1979 Ford Bronco with original axles. I put a new master cylinder probably Feb 2010 because it was leaking between master cylinder and booster. I have also replaced front brake lines. In June 2010 I had both front calipers start sticking one day and then it didn't do it anymore until Nov 2010 but I also don't probably put 150 miles on it a month. But the thing is sometimes it sticks after you press them then sometimes you can be driving and not press brakes for 4 or 5 miles and all of a sudden both front brakes will start locking down without ever applying them. The interesting thing is you can get out and loosen the front bleeder screws and fluid will shoot out about 8 or 10 inches and they will release and you can drive again. I replaced both front calipers about 2 weeks ago and still doing same thing. The right one is worse than the left but both will do it. I drove it maybe 10 miles today and had to stop and bleed the pressure off about 4 or 5 times. Any help would be appreciated this thing has me stumped. I have seen vehicles brakes stick and not release but never start locking down without applying the pedal. Thanks in advance.
