front and rear end id#
busterbronc
does any one now where to decode id numbers for front and rear end on 79 bronco?
Post them up here, and someone will decode them. The front axle is a Dana44, the rear is a Ford 9". The gear ratio will also be stamped on the bottom line of the metal ID tag bolted to the center or differential, i.e., "3L50 9 ..." if it's a factory limited slip option. JSM84
Sandoval_broncosauria
