Front ABS Speed Sensor
aintnorest
In the process of replacing the left front axle u-joint on my 95 fsb. I'm down to the spindle about to remove 5 nuts to pull spindle, but first I need to remove the abs speed sensor. Removed one small long bolt from the back of the sensor, no budge. how does the sensor dis-assemble. There is a front block that the sensor goes thru that is half mounted to spindle plate. Can't remove spindle to pull axle to replace u-joint, have to remove this first.  :mad:
Rons beast
Hey aint,  Welcome.
After the bolt is removed the sensor is pushed out front, (or outside) to inside.  They can get pretty mucked up.  sometimes you need to give them a "nudge" with a wooden dowel and hammer.
Good Luck
figjeti
