finaly
muddinlate86
va.beach
i think my new injecters are finaly broke in my truck is starting to get some of its balls back, i hit 70 this morning on my way home!
also will me having to adjust my tps cause my truck to not stay in over drive? it shifts fine but to get it into over drive i have to let off the gas but after a min itll shift back into 3rd? any help?
shift1313
VA
is your speedo corrected for those tires? Larger tires and not speedo correction will mess with OD
muddinlate86
muddinlate86
va.beach
yeah i belive it was calibrated, well i mean when i pass a cop i make sure im not going faster than the rest atleast.hahaha
Well, to be honest at 3:45 I'm just not motivated enuf to dig out the factory manual to look, but I WILL take a gander at it 8 or 10 hrs from now when I wake my a$$ up. However, I looked some of this over last week on an unrelated question and didn't see any notations about TPS adjustments effecting the 3-4 shift. You mention having an AOD. The AOD's are *really* touchy when it comes to the throttle pressure. If it's out of adjustment then it causes late/slow shifts and the sort of problems you're describing. In a 22yr old truck *I* would take it to a tranny shop to have the throttle pressure ck'd & properly set. It's also a good idea to have it ck'd because an out-of-whack throttle pressure is something like THE #1 reason AOD's burn up. Having it ck'd and adjusted every several yrs is NOT bad advise.
As far as Shift's comment goes, either the speedo *was* recal'd for the current tire size or it wasn't. There's no middle ground. Larger tires on an 86' will require a new speedo gear. You can either have a local speedo shop look at it and get you what you need or contact the tech-support line from one of the larger 4x4 retailers and they'll be able to tell you what gear you'll need for the tire you're running, but if you haven't replaced a speedo gear then you haven't corrected the speedo for the tires.
BroncoJoe19
New Jersey
I'm with BrocoBill78 on this one. My understandning is that the tps needs to be adjusted so that you have a correct idle. And while I have *heard* that information sent by the TPS is used by the computer to set shift points, I have not read it by any definitve source. IF you didn't regear when you went to 35s I am guessing that as you go up any kind of grade, and give it a little gas, your trans would normally drop out of OD.
You may be tricking it into thinking there is less load on the engine by taking your foot off of the gas, so that it will drop into OD, and then when you reapply the gas, it senses the load, and has to downshift to 3rd. Perhaps you should have someone drive it who has a lot of experience driving a stick, and ask him/her to evaluate whether or not they feel that there is a problem. Not to take anything away from you, but I mention this becuase when someone has a lot of experience driving a stick they feel the torque curve, and listen to the engine to the extent that they shift gears wihtout even thinking.
BroncoJoe19
New Jersey
Thanks to Miesk5 for this.
Bronco's prior to 1992 uses a geared speedometer/odometer
Gears for 2WD manual trans Ford vehicles & all 4WD pre-92 trucks
Source: by Fireguy50
http://www.fullsizebronco.com/forum/showthread.php?t=109671
This link teaches one how to calculate which gear should be used to replace their present gear to recalibrate the spedometer due to either gearing or tire size changes.
muddinlate86
muddinlate86
va.beach
thank you guys for your help i talked to the previouse owner and he had 456 gears put in front and rear and did get the speedo cali.however my tps is a little off when i put the voltege meter on it but its a pain to get to.mine is upside down.oh well another day another dollar.i also found out this weekend that my truck is not made to play tug of war with a 06 f350 in a mudd hole thatd been tore up by 44 inch boggers, needles to say i lost when my front drive shaft decided to take a "break" luckly i had a spare
