extended brakelines
BLADE262US
Michigan
You should really use them but if you dont have the cash you can make new brackets and move them lower on the frame then youd probably be alright . :D /emoticons/[email protected] 2x" width="20" height="20" />
ocalabronco
ocala, Fl
they aren't "needed" per se. it is a very good idea to invest in a set, but you can get away with a 6" kit with stock lines as long as you dont wheel it really hard and constantly flex your suspension to its max
hmbrewr
I had to use them on my 6" lift. Especially with new springs. They'll sit a little higher until they relax a bit.
Besides, if they're OEM then they're 25 years old! If they're stretched and one breaks, it's to late for "I should of ...!"
eholt80
