exhaust manifold and crossover
wtfdissux
Buffalo, NY
i went out on a fun run and it turns out that all the shaking and bounce did not do nice things to my truck seems i broke the exhaust ****** at the manifold on my 351 am not really looking forward to repair as the studs look like rusty tooth picks so may get new manifolds before i start but this leeds to an interesting problem
i cant find a crossover pipe anywhere for my truck and seeing as i work for a muffler and brake shop this is about the last problem i would expect any one know where i might find one or am i stuck doing a custom bend dual?
grande_guerre
grande mondiale
originally-Alaska, temporarily-Arizona
hey, if you can find someone who makes 'em, let me know. I wanted/needed to replace mine, but i ended up just having the holes all welded in and rebended and blah blah blah. It was a pain. Good luck, and you might be stuck making one...
W
wtfdissux
Buffalo, NY
I could probobly make the duals with cats and mufflers under 300 but the point is except for some small changes my trucl is still stock and like the idea of keeping it that way if it was my 86 i could care less
rubberdust
Henderson NV
LMC Truck has complete crossover exhaust with the catalytic converters for about $300
(1-800-562-8782)
But as I found out with a different oil pan :blush: it didn't quite fit but it comes as a complete unit & will bolt directly to stock manifolds & if you haven't changed oil pans you should be in great shape
brian_n_texas
Melissa, TX
Summit and Jeg's both have crossovers, and lots of other exhaust components...I am looking all over 'cause I am about to upgrade my exhaust.
brian_n_texas
Melissa, TX
After you get yours fixed, take a pic of the result, I'm trying to figure out how I'm gonna route dual pipes.
eholt80
