EGR ?
biker3r
Went to the smog test place today, passed emissions test no problem, but fail the vac test on the egr. mech. told me it wasnt getting vac to the egr. Got thinking about it. when warmed up and running their shouldnt be any vacuum going to it,or should their be? Dont think so Or am i all wet.,,,,,Dale
biker3r
Guess i should post this in the tech section, sorry im a newbie
Bronc76
The signal that operates the valve at the EGR port is vacuum, and sometimes the signal is controlled by one or two valves.
Great advice!
Here is the EGR Section in my site;
http://www.broncolinks.com/index.php?index=146
Testing; "...There shouldn't be any vacuum at the EGR valve at idle or any time your ass is under the hood fiddling with it, to put it plainly, except for perhaps a very light residual vacuum from the EVR. Check ALL of your vacuum lines FIRST, and the vacuum reservoir for leaks..." Source: by SigEpBlue
I forget how much you know already about the EGR system, comonents functions & locations as well as da Air Injection (AIR), Secondary Air Injection; Pump (Smog Pump), Thermactor Air Bypass (TAB) & Thermactor Air Diverter (TAD) Solenoids; Diverter, Check & Bypass Valves, Cross-Over Tube, etc.
http://www.broncolinks.com/index.php?index=416'>http://www.broncolinks.com/index.php?index=416
In both sections there are locations, function and testing info
Do you have a Trouble Code or CEL?
its a 91, right?
Think you know about A Self Test for Diagnostic Trouble Codes (DTCs) by buddy, BroncoJoe ?
http://broncozone.com/topic/14269-code-reader/page__p__74587entry74587
I run it around to heat the engine up and shift thru all gears incl Reverse.
then; turn off all accesories/lights, etc.
Do KOEO portion first
For Key On Engine Running (KOER) portion, the engine has to be @ normal operating temp.
Post any codes found here or look em up in my broncolinks.com site using the Search feature or in each section
Use the VECI Label showing da Emission Vac Diagram on radiator to go thru the hoses for a leak
Vacuum Diagram is the same as the one on the core support or hood or air filter cover.
Source: by Ford motorcraftservice.com
http://www.motorcraftservice.com/vdirs/retail/default.asp?pageid=&gutsid=
On-Line for Free at Ford. Click "Quick Guides" in left panel;
Scroll to & CLICK VECI Labels "Provides Vehicle Emission Control Information (VECI) and a related calibration parts list."
Enter applicable info (need to know your Calibration number from your B-pillar sticker).
VRESER is the Vacuum Reservoir Can (Tank); Location pic in an 89 5.0 (Adam Titled it as "This")
Source: by AdamDude04 & miesk5 at Ford Bronco Zone Forums http://broncozone.com/topic/19892-whats-this-hose/
ACV (Air Control Valve) is the TAD (Thermactor Air Diverter) Valve (AIR Bypass (AIRB) and AIR Diverter (AIRD) valve combinations)
Thermactor Air Bypass (TAB) Solenoid (SOL V) (AIRB) see http://www.broncolinks.com/index.php?index=416
Thermactor Air Diverter (TAD) Solenoid (SOL V) (AIRD) see http://www.broncolinks.com/index.php?index=9
ACV (Air Control Valve) is the AIR Diverter (AIRD) valve; also called the TAD (Thermactor Air Diverter) Valve
AIR BPV is the AIR Bypass (AIRB) valve; also called the TAB (Thermactor Air Bypass) Valve
MAP is da Manifold Absolute Pressure Sensor
EGR is Exhaust Gas Re-circulation Valve
EVP is EGR Valve Position Sensor
EVR is EGR Vacuum Regulator
FPR is Fuel Pressure Regulator;
Carbon Can is da Carbon Canister (Charcoal Canister, Vapor Canister, Evaporative Emission (EVAP) Canister
CPRV is Canister Purge Solenoid Valve/ Canister Purge Solenoid (CANP) is controlled by the PCM to vent fumes from the charcoal canister to intake manifold only when the engine is running; pic in a 90 by Seattle Bronco at http://www.supermotors.net/registry/media/795183
V REST on later years is Vapor Valve (Roll-Over); Depictions & Location Diagrams in 5.0, 5.8, 7.5, & 4.9; "...All fuel tank vapor valves make use of a small orifice that tends to allow only vapor and not fuel to pass into the line running forward to the vapor storage canister. This assembly mounts directly to the fuel tank using a rubber seal. Fuel vapors trapped in the sealed fuel tank are vented through the orificed vapor valve assembly in the top of the tank. The vapors leave the valve assembly through a single vapor line and continue to the carbon canister for storage, until they are purged to the engine. The vapor valve assembly mounted on the top of the fuel tank is used to control the flow of fuel vapor entering the fuel tank vapor delivery line which conducts vapor forward to the canister in normal circumstances. If due to extreme conditions, excessive pressure is generated inside the tank, the purge port opens up, allowing fuel vapor to escape to the atmosphere, and stabilizes pressure inside the tank. The valve assembly has a head valve which prevents the fuel tank from overfilling during refueling operation. The valve assembly also has a spring supported float assembly, which prevents liquid fuel from entering the vapor delivery line during severe handling, steep grades or in the event of vehicle rollover. The fuel fill cap is sealed and includes a built-in pressure-vacuum relief valve. Fuel system vacuum relief is provided after 3.5 kPa (0.50 psi) and pressure relief after 11.0 kPa (1.6 psi). Under normal operating conditions, the fill cap operates as a check valve, allowing air to enter the tank as fuel is used, while preventing vapors from escaping the tank through the cap..." by Ford via Steve83 at http://www.supermoto...ry/media/283481
Vapor Valve (V REST) pics in 5.0, 5.8, & 4.9...The smaller valve uses a thicker grommet to fit in the same hole as the larger one..." by Ford via Steve at http://www.supermoto...ry/media/767956
V REST on earlier years such as SEABRONC's 83 is a Vacuum Restictor/delay valve, it delays vacuum for a certain amount of time. See his Vacuum Line Diagram (modified to reflect changes He made) at http://www.supermoto.../media/672883_1
VCKV is Vacuum Check Valve
MAN VAC is Manifold Vacuum
CAT is the catalytic converter
ENG is the engine
PCV is Positive Crankcase Ventilation Valve
EFCA is Electronic Fuel Control Assembly/ (Fuel Pressure Regulator (FPR)
more by our PAL SEABRONC & Steve83 (includes Carbureted Models)
SV CBV = Carborator Fuel Bowl Solenoid Vent Valve
LCV = EGR Load Control
WOT =Wide Open Throttle) Valve
HICV = Hot Idle Control Valve
IVV = Thermactor Idle Vacuum Valve
VRDV = Vacuum Delay Valve (VDV, VRDV, DV-TW)
VDV = Vacuum Delay Valve)
VRDV = Distributor ****** Delay Valve
DV-TW = Two Way Delay Valve)
HEAT VLV INT = Heat Vacuum Control Valve Intake, (next to carb)
In an 85;
Red = Main vacuum
Green = EGR function
Orange = Heat control Valve (exhaust & intake) (AKA heat riser but more complex)
Yellow = Distributor advance
White = EGR vacuum (source)
Black = Mainly used for the Evaporative emissions control
Black = Thermactor ACV or diverter valve
Blue = Throttle Kicker Solenoid (TKS) which sends vacuum to a vacuum motor to boost the idle a set amount
Pink = Thermactor Air Bypass Valve (BPV)
by AsianSpanker
CL: Located in the air cleaner
A/CL DV: Air Cleaner Diverter Valve
A/CL BI MET: Air Cleaner Bi-Metallic Valve
A/CL CWM: Air Cleaner Cold Weather Modulator
ACV: Air Control Valve
AIR: Ford calls this the Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
AIR BPV: Air Bypass Valve (aka Thermactor Air Bypass TAB)
BV: Bowl Vent (on top of the float tanks)
CARB: Carburetor
CPRV: Canister Purge Valve
DIST:
EGR: Exhaust Gas Recirculator
EFCA:
FLTR: Filter
FPR: Fuel Pressure Regulator
IVV: Thermactor Idle Vacuum Valve
MAN VAC: Indicating Manifold vacuum-Vacuum source
MAP: Manifold Absolute Pressure
SOLV: Solenoid Valve
SV-CBV: Carburetor Fuel Bowl Solenoid Vent Valve
VAC:
VCKV: Vacuum Check Valve
V CK V: Vacuum Check Valve
VRDV: Distributor ****** Delay Valve
TVS: Throttle Valve Solenoid (aka Solepot, Dashpot)
TVV: Thermostatic Vacuum Valve (aka Ported Vacuum Switches)
PURGE CV: Vapor Canister Purge Valve
Color Codes to do Vacuum Diagram
Red = Main vacuum
Black = Thermactor ACV or Diverter valve
Blue = Throttle Kicker control
By WEBMASTER at http://www.fordtruck...read.php?t=1703
A/CL: Located in the air cleaner
CARB: Carburetor
DIST:
FLTR: Filter
VAC:
Color Codes to Vacuum Diagram
Red = Main vacuum
Overview & Diagram; "...Secondary Air Injection system consists of a belt-driven Air Pump, single or dual AIR Diverter valve(s), an AIR Bypass valve, and AIR Bypass solenoids, air silencer/filter, Powertrain Control Module and connecting wires and vacuum hoses. The Belt-Driven Secondary Air Injection system provides either upstream/bypass air or upstream/downstream/bypass air. The number of these system configurations vary significantly with AIR Bypass and AIR Diverter valve combinations (Figure 179). 2. The PCM provides one or more signals that enable one or more AIR Bypass solenoids. 3. The AIR Bypass solenoids control one or more AIR Bypass valves and/or AIR Bypass Diverter Valves in order to route secondary air depending upon the specific configuration. 4. The belt-driven Air Pump is operational any time the engine is running..." read more
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
"...The 2ndry air system is known to fail in a wide variety of ways. The check valves that prevent hot exhaust from entering the rubber hoses age, rust, leak, & crack open melting the plastic TAB & TAD valves, creating exhaust leaks that can damage other components, raising exhaust oxygen levels (setting lean codes or rich adaptive limit codes), and making rattling noises. The hard steel tubing between the exhaust & the check valve can rust or crack (especially the infamous "crossover tube" on the backs of V8 heads). The vacuum controls leak (including the coffee can reservoir on the R wheelwell) (Miesk5 NOTE, this is the Vacuum Reservoir (VRESER), it stores excess vacuum to prevent rapid fluctuations and sudden drops in a vacuum signal, such as during acceleration) get misrouted during other repairs, or the diaphragms rupture. The electronics that control the vacuum controls can fail electrically or mechanically, or the wires can be damaged. But all of these failures are either A) relatively cheap & easy to repair, or B) cheap & easy to prevent with normal inspection & maintenance..."
http://www.supermotors.net/registry/media/589993
biker3r
Jus got off work, sorry for not responding earlier, thanks to all for the info, gotta get my act together and give more vehicle info, im used to my harley forum where everybody knows about my ol POS , Yes Miesk5 its a 91 5.8 with auto trans, im going to do some reading befor i ask anymore ?s thanks again and ill let yall know what i come up with,,,Dale
BubbaBronco95
Had the same problem on mine. take off the hose connected to the egr valve, with the engine off blow into the hose. if u hear air leaking, just find where and replace with vacumm tube. my check engine light was on and after i did this it went away, quick and easy fix hope it helps.
biker3r
Got the bronc to pass smog today, Went tru all the test suggested by Miesk5 , found a somewhat loose wire on the EVR, other than that it all checked out ok. the Evr still showed it wasnt working at smog station,untill he put it on the treadmill,not required where i live in the mountians, once he got the tires spinning the sucker worked and passed smog, Guess i learned sumpin today,,,,Dale
