Driveshaft
fordblue
Put 35 tires on,now my u joint on my rear drive shaft keeps twisting,breaking...help!!!
Txquadhunter
N. Texas
did you lift the bronco? if so the pinion angle could be off causing the trouible. If not be sure to use good U-joints. the cheap auto zone joints won't cut it. also the u-joints are the weakiest link in your driveline.
Billz4x4z
Carnesville,GA
With the bigger tires your gonna get alot more twist of the axle,especially if your using a lift block,thats gonna eat u-joints on a regular basis.Like what was said in the previous post if ya did lift it you driveline may be outta line also.
T
Tom Kelly
Guest
Hello! Where can I get or order a bug deflector for my 79 Ford F150 ? Thanks Tom
Staff online
stevedave
