Door seals?
Burns
Royersford, PA
When I'm driving, I can feel cold air coming in from somewhere. I'm pretty sure it's the door seals, as I can see sunlight through the main pillar and the door when the door's closed. Any tips on finding the leak if that's not it?
Take a piece of thin card board, (like the back of a note pad), and close the door on it so you can slide it along the edge. It should feel snug, if not you found a problem area. The best thing to do if the door closes properly , is to replace the old seal. It also may be comming through the door panel. On new doors the holes are sealed with a kind of paper, it may be missing or just deteriorated with holes or loose. You can replace that also. If you have an outside floor vent check the seal of the slider door.
eholt80
