:huh: I just purchased my second Bronco, an old 75 that you can see the ground in the floor pans. It's going to be a frame off, and the biggest problem I have come across is the DOOR RUST. Not the frame but the doors themselves. The front of the door were the hinges mount are bad and the bottoms are bad. The window frames are good but are cracked and need to be welded back in place. Most every other part for the truck can be found for replacement, but the doors are stumping me. Any ideas for repair skins or just some good replacement door locations??? Thanks for the help and I look foward to many more questions.
