Does anyone......
Bronc76
.... have an emission diagram or pics of a '76 Bronco other than what chilton shows?
andre
gatineau hill quebec
NEED INFO
ENGINE SIZE AND TRANMS TYPE
MORE INFO BETTER CHANCE OF GETING RIGTH DIAGRAM
MAY BE ABLE TO GET FROM WORK
Bronc76
Read my signature.
If you can find something, that would be great.
andre
Bronc76
I'm looking for a vacuum diagram. There are two lines that go from passenger side exhaust. I know they go to back of carb, but where? I think I got the lines that come off the air cleaner hooked up correctly. Also, just curious if anyone knows where the catalyst protection temp. sensor wires go, or is there really such a thing?
andre
here some "Q"
i need to know
is it org carb and air filter bowl
do you have charcoal canister and engine air pump
on r side of engine there two hose
i got hayne can copy page and try to send you it
if you whant it
Bronc76
Original motorcraft carb and airfilter bowl, it does have a carbon canister. As far as the air pump, it doesn't currently have one but the alternator has a double pulley and there is a bracket above the alternator. Is that where the pump should be? I'm assuming since its a '76 that it should have one. I'm trying to rebuild it back to original.
andre
ok air pump is on r side of engine under alt
on str 6 on top if mem serve me
some did not come w air pump
did you try the dealer to see if can get fax of engine parts whit youre ser no#
or may have micro fiche you cant take a look at
ill try on my side see if i can get any info
have a rager whit 289 from 1969 bronco still running strong
tranmission and t-case in garage love the t-case gear dive no chang
be in touch let you know if i get any info
figjeti
