custom exhaust
murph
North Carolina
I'm getting new exhaust next week. Is there any way to stop the fumes from coming in the back window? It's almost unbearable.
gungho
so i'm guessing that you are dumping your exhaust before the rear axle? Because if you are the only help i can give you is that you need to put some kind of tip on to point the exhaust at the ground. It will help a little.
The main problem is the aerodynamics :)) of the truck causes it to **** air in the rear window. I use a deflector on top of the cap which helps if I only open the window about 1/2 way. You will also **** air in under the tail gate if the seal isn't good. I have the feeling that the only real solution is pipes that extend about 3 ft. behind the truck :mad: .
88pimpin
Postwhore, Pimpin Ain't Easy
Bozeman, MT
I have mine coming out behind the tires for that reason. I paid $180 installed for mine. Cut off the cats, run pipes off each exhaust manifold to a pair of glasspacks and out the the back sides.
wrachet
Kansas City Area
Nauseating is what it is!!!
Good thread because if I end up keeping the restore Bronco...somethings changin' with the exhaust!!! I'm thinking side pipes.
Colleen
eholt80
