Cooling
bbguns
Installed a Vintage Air A/C setup in my 69 Bronco, and now the motor runs hot in the Vegas summer. Want to install a radiator better than the stock 3 core but not alot of clearance.
I've put a pusher fan on the front of the condenser, pushing thru that and the radiator.
Is there a better radiator out there that is the same thickness as the stock 3 core, or does anyone know of a different bracket and a/c compressor setup that would allow a bigger radiator?
Yes I run with a fan shroud, just had to take it off for the pic.
Any help would be GREATLY appreciated!
Looks to me to be at least 1" clearance (fan to rad.) & 1" clearance (fan to compressor clutch) ..... that's 2"
How 'bout a thinner fan, a shorter fan adapter, & a 4 core aluminum rad. ...?
But it seems just a shorter fan adapter would give enough room.
