clutch hose O-ring
shouldaboughtajeep
Bullhead City AZ
HELLO I NEED help i recently did a cluch on my 89 ford bronco and the line tht connects to the cluch master will not seal is it a special o ring???? or a normal one becuase all the ones i used will not seal it please get back to me on where i can find the right size or the right one please and thank u
tiller83
baton rouge
you should be able to get them from a parts store,i think there green,and you gota bleed it after. you may have to purchase a new hose to get them.
Edited by Seabronc to remove unnecessary negative comment.
S
shouldaboughtajeep
Bullhead City AZ
is ther eany way i can get them with out buying the hose because i baught a cluch master cylender just for tht peice and it ripped :( /emoticons/[email protected] 2x" width="20" height="20" />
50joe
Trenton NJ
Have had those go bad on our tow trucks at work. If you can find a good assorment kit somewhere, any color should work. And the extra o-rings are always a graet thing to have around. Can never have enough useless junk laying around. Never know when you may need it.
kyleh01
