centech wiring
73dreambronco
what wires should be running to the starter relay(selanoid)can someone show me a pic or just brake down what wires go to what post. (including neutral safety wire)
thanks, matt
BASE861
The Big Nothin'
East Coast
what wires should be running to the starter relay(selanoid)can someone show me a pic or just brake down what wires go to what post. (including neutral safety wire)thanks, matt
33568[/snapback]
Since you have a truck with a neutral safety switch find the purple "starter" wire in your passenger side harness that is long enough to go over the firewall to the NSS connector and back to the starter solenoid. You will need to cut the wire so that there is a break in the wire via the NSS and return back to the solenoid "s" post.
