ColoradoBroncoman
- Joined
- Mar 2, 2008
- Messages
- 8
- Reaction score
- 0
I have a '94 Bronco that I cannot turn off with the key. I can start it up with ease, but when I go to turn it off the ignition switch would turn and turn and turn. Also, while the truck is running I can pull the key out and the truck will still be on.
I have disassembled the steering column as much as I can, and there is a white plastic rod that runs from the ignition switch where the key is - all the way along the right side that would connect with the circuit under the column.
I am not sure if the rod is suppose to be on pieces or two pieces. I cannot remove it. (dont know how)
Can any one give me a heads up on which piece is broken.
THANKS
THANKS
