cams
mbtech2003
cape cod, mass
i was thinking of putting a new cam in my engine to get some more power out of it. i was thinking of this cam 270-443904 from jegs.
http://www.jegs.com/cgi-bin/ncommerce3/Pro...902&prmenbr=361
any info would be helpfull and should i do it with 120k on the clock??? i've allways changed the oil every 2500 miles scence i owned it and their is no unusall noise from the engine besides the broken manifold that i will be replacing soon. i will be pulling the engine out so i can replace the rusted oil pan and leaking rear main seal :(( i will however replace the timing chain and gears eather way.
thanks
bluesman17
Spam Terminator
South Bend, Indiana
If your going to pull it why not take it somewhere to be rebuilt and do any upgrades then? That is what I would do, but just my opinion.
mbtech2003
mbtech2003
cape cod, mass
i guess i'll see what the engine looks like when i take off the oil pan and intake and valve covers and go from there. and hope that i dont have to rebuild it. :wacko:
brian_n_texas
Melissa, TX
Since you're putting in the time and effort to pull the engine - which ain't easy - I would suggest at least getting remanufactured heads, or take 'em somewhere and get 'em redone. I put reman'd heads on my 82 that had 147,00 miles when I got it and every time I have checked the oil since it's clean enough to see through.
One note: when you swap a cam, you want to make sure it's compatible with your stock valve springs, lifters, timing gear, etc.
mbtech2003
mbtech2003
cape cod, mass
ya i prob will have to upgrade the computer. i think super chips has one i'll look into it
hypertech has it for bout $260....
now just haveto find a weekend and start pulling it out :))
might be a few weeks yet but any other info would help in the mean time for things to think about while i'm in there
thanks again
BLADE262US
Michigan
I wouldnt mess with the computer you could end up in a tuning nightmare . The cam I used in my 351W when I rebuilt it is one that comp cams makes specifically for the fuel injected 351W . It has been a very good cam so far very happy with it and you dont have to change the computer because its ground within the limits of the computer fuel and timing map . :D /emoticons/[email protected] 2x" width="20" height="20" />
hfrost112
