Build sheet
n2spd
Does anyone know how to get a build sheet or know haow to read codes. I have a 1989 Bronco with a 5.8L 351 and automatic trans. I would like to know what trans and transfer case i have. I would also like to know what heads I have. Thanks for your help. Sorry if this was supposed to be in technical
yo!
Build Sheet Information Phone Number, Ford (1-800-392-3673) - FREE!
here is what you will receive from Ford
Build Sheet Information Form; Fords build sheet reply letter w/original build date, optional equipt., axle ratio, paint color, etc Source: by equivalent
you have a Borg Warner 1356 tc
and most likelt an AOD tranny; If the shifter has a P-R-N-OD-D-1 pattern, the transmission must be an AOD (applicable to 1980-1993 vehicles).
If a 1989-1993 truck has an Overdrive Cancel Switch and a P-R-N-OD-2-1 shifter pattern, then it is equipped with an E4OD transmission. With the possible exception of some 4R70W equipped 1993 E-150 vans with 5.0L SFI engines (The existence of a 1993 4R70W van is unsubstantiated). by Baumann
head...see casting number; and then http://www.cehighperformance.com/ford_bloc..._codes.htm#351W
gl!
N
n2spd
yo!Build Sheet Information Phone Number, Ford (1-800-392-3673) - FREE!
gl!
Thanks for the info. My shifter pattern says P-N-D-1-2 so I guess its a 3 spd.
gatorbronco
Gainesville, FL
Dunno if i'm special or not, but when i pulled the carpet up in the back of my bronco I found the original inspection/spec sheet from the factory...it was pretty neat to look at and see every detail about the bronc.
yw
and ty gator for pointing that location out; also, some sheets sre under rear cargo mat/or carpet, depsneding on model trim level.
what the sheet looks like:
Build Sheet for an 86
Source: by Aikidoka (Adam O) at aikidokatech.com
have to go thru my back-up discs for some legends I have accumulated over da years and lost in the SuperMotors crash a few years ago.
Coastersfwb
