Bronco Shudders during acceleration.
RandomSignal
Texas
Hello. I have a 95 5.8l 351w Automatic Eddie Bauer. Every morning when I drive to work, my Bronco shudders and has a hard time accelerating once I hit 35 mph all the way to highway speeds. Once I hit 75 mph, it stops and then drives and shifts gears smoothly after. It has done this every morning in the past week or so. I have had the spark plugs, wires, cap and rotor replaced in the past two months along with the TPS. Is this a torque converter issue? Thank you in advance.
Good call on the ATF. Seems like every Bronco that I buy with an E4OD requires a complete flush berfore I can add miles on it. The speeds that you mentioned above are in the exact range for a failed PSOM. I had to pull the one out of my '93 last month and have it rebuilt at a local module shop.
Before Pulling the dash I tryed changing the speed sensor, New rear diff fluid, Checked the ABS module, and crawled the wiring.
R
RandomSignal
Texas
Thanks, Skitter. I replaced both fluid and filter and I did notice a little improvement, but not much. Would a bad PCM cause the PSOM to be faulty? The reason why I ask is because I was troubleshooting the 558 code and after doing it step by step, it tells me that I have a bad PCM. I may replace it first before I go through the trouble of pulling the dash.
The Speed signal goes from the PSOM to the PCM. So normally when I see a shudder issue on these years of Bco(s) its either an issue with the signal going to or leaving the PSOM. On thing to verify is that the frequency of the pulses leaving the speed sensor and make sure they match the signal going to the PCM.
If you think the PCM Might be bad it might be time to yank it and inspect the board.
R
RandomSignal
Texas
Thanks. I also got a code 512 KOEO as well which leads me to believe it's bad as well.
Yo
DTC 512 "...indicates the PCM has experienced a power interrupt in its Keep Alive Memory (KAM) circuit. If KAPWR is interrupted to the PCM, for example when installing a breakout box, or when battery is disconnected, DTC 512 may be stored in Continuous Memory. Key off. Disconnect Powertrain Control Module (PCM). Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary. Install breakout box, leave PCM disconnected. Measure voltage between Test Pin 1 and Test Pin 40 or 60 at the breakout box. While observing DVOM, grasp the EEC-IV harness and wiggle, shake or bend a small section while working from the PCM to the dash panel. Does DVOM indicate less than 10.5 volts? Make sure you have a good ground at G101 (Passenger of engine compartment, near battery). If so I think I would go ahead and change the PCM as I do not know of any thing else out side the PCM to cause this..."; Source: by subford
Inspect PCM...
Open EEC and look for leaky/burnt capacitors.
Capacitor Repair in a 90 5.8
Source: by dolittle (seedpress) at Fuel Pump Runs But Engine Won't Start
"... finally pulled the computer and, sure enough, two of the electrolytic capacitors had leaked. Not only were they shot, but the leaked electrolyte had begun corroding some pins on one of the semiconductors. The computer board is covered with a conformal coating to protect it against moisture and contamination, but the electrolyte had also seeped under or through that coating and discolored the board in places.
First I cut out all three of the electrolytic capacitors, although only two of the three had leaked. Then I tried to clean the spilled electrolyte. To remove the corrosive electrolyte I had to strip off the conformal coating where I saw board discoloration. I tried to clean the affected areas with rubbing alcohol, dilute acetone (used for finger nail polish remover), and WD-40. Also, one logic IC (integrated circuit) had three pins that were corroded by the electrolyte. I tried as best as I could to clean them mechanically.
The two leaking capacitors were 47uF 16V, and the third a 10uF 63 volt. I didn't have these values on hand, but coincidentally I had just bought a hundred 22uFs with a 63V working voltage. So by paralleling two of the 22s I was able to get 44uFs, and in series I got an 11 uf. Electrolytic caps have a wide tolerance range anyway, so I hoped that would be good enough. The one problem was all the original caps were 105 C temperature, whereas my replacements are only 85 C. But my computer is behind the driver's kick panel, instead of in the engine compartment. So, I am hoping it will work, at least for a while.
It was a pain to replace the caps! First, I found it difficult to solder the new, "paralleled" capacitors to the printed circuit board. Then, I wasn't sure how many layers the board had -- it's easy to overheat and ruin underlying layers. Finally, some of the copper pads to which the new caps were being soldered were also very close to fine-pitched copper traces. My finished "repair" is a real mess! But it seems to be working.
'90 Bronco EEC Interior Photo by dolittleproject @ '90 Bronco EEC Interior Photo by dolittleproject | Photobucket
Some pics by jowens
MIESK5 NOTE, as I mentioned in another thread here; In place of the breakout box, go to the EEC CONNECTOR's pin(s) instead
Ensure battery is fully charged
Run the engine at 1500 rpm with no electrical load.
Read the voltage. The voltage should be in the range of 14.1 to 14.7 volts.
Pin 1 is KA PWR – Keep Alive Power
Pins 40 is Ground
Pin 60 is Ground
The Keep Alive Memory (KAM) within the processor must always have voltage supplied to it. This voltage is supplied by the Keep Alive Power (KAPWR) circuit (Pin 1) that connects directly to the battery. KAM contains adaptive parameter tables that allow the processor to adapt to different operating requirements. It also contains the Continuous Memory codes. Continuous Memory codes will be erased any time KAPWR is disconnected (i.e. battery disconnected, processor disconnected, breakout box installed, open in the wire, etc.). If KAM fails within the processor, all Continuous codes will also be erased.
Also caused by;
Battery terminal corrosion
KAPWR to PCM interrupt/open
Loose battery connection
Damaged PCM (less likely)
...basically, if the truck is running fine, don't worry.
Val
