Breaking the code
Phil76
Aransas Pass, TX
I would like to add all of the pertinent information on my newly purchased 76 Bronco, but I'm having a tough time determining the codes from inside the glove box. The code is as follows: 092 u 0150 rv 9 18 04400 1976 52 Can anybody help with this? Thanks.
Hi Phil..,
No real need to be "spot on specific".... :)>-
General info. is good enough for starters & can always be up-dated.
092 is wheelbase (don't need that)
U15 is hardtop wagon (don't need that)
Basically.., eng.,302 transmision., 3 speed man. P/S etc., etc.,
You know..., anything you know to this point.
Note any changes made by prev. owner. (carb., distributor, etc.)
Look at some of the other members post & use that as a guideline...
(they're all a bit different as to format so no real set rule) B)
Do the info. under your name as well., that can be helpful too.
Phil76
Phil76
Aransas Pass, TX
Thanks. Can I tell the front/rear gear ratio from these codes, or am I going to need to find the tag on the diffs themselves?
"Can I tell the front/rear gear ratio from these codes, or am I going to need to find the tag on the diffs themselves?"
This works in a perfect world... but, who knows what the PO put in there..?
Chalk mark the wheel & dr. shaft. Turn the wheel one rotation (jacked up in neutral) count the # of turns on the shaft.
I'm guessing you'll get 3.5 turns. (In some cases, you need to stop the wheel on the other side fr. turning.)
3.5 turns = 3.50's 4.1 turns = 4.11's, etc.
Gary wilder
