Blinker wire
monsterbronco
Mississippi
Having trouble getting my driverside front blinker to work, all the rest are working fine . Tested it last night and it is getting no power, can I just trace it back to the harness and run a new wire from harness to the blinker.
"Tested it last night and ...."
How....?
This prob. usually ends up being the ground., or a bad bulb.
Back test the + side 'til you find power...if in fact it's not gett'n the 12 V to the bulb socket.
M
monsterbronco
Mississippi
"Tested it last night and ...."How....?
I used a voltage sniffer. I traced the wire back through the harness and found where the harness had been cut and spliced. I pulled the wire and replace it with a new one but used the old connectors. It blinks a lot dimmer than the passenger side but it blinks so I'm happy now. Any idea why it would be blinking dimmer?
Sandoval_broncosauria
