Biggest enigine but not diesel
Up to 96 it was the 7.5 Liter 460ci 245 HP @ 4000 RPM MPFI. I believe some of the newer engines are larger such as the V10 but don't know it's specs.
Shadow_D
Schenectady, NY
Before you go and spend all your pennies on the "Biggest" motor you can fine, do some research on the new Mustang V8. I think it puts out around 300hp STOCK!
It's a 4.3L or something small like that. Imagine what you can do to bring up the HP with that :-B
If you were to put it in a Bronco you would have to re-gear it so you don't waste all that HP trying to move that big bruit.
Just my $0.02 :closedeyes:
fordfanatic75
martinez c.a.
Before you go and spend all your pennies on the "Biggest" motor you can fine, do some research on the new Mustang V8. I think it puts out around 300hp STOCK!It's a 4.3L or something small like that. Imagine what you can do to bring up the HP with that  :-B
19753[/snapback]
Shadow d has a good point. if your making this wheeler and not just some pretty hot rod street truck. Not that theres anything wrong with that!! the less weight you have the better. especialy for balance front to rear. the difference from big to small block is probly 500 lbs the ONLY major advantage to the big block is the torqe, or yourpower at take off. if your building a wheeler thats where low range comes in!
cowboydan
some times all you need is a set of gears to make it all better.
S
sreaminbronco
Dallas
Hey guys i love wheeling just as much as the next guy does but everytime i got i come back with a $300 or more problem and i dont have much money so I want to make my bronco a tall ass hot rod because out here in mesquite texas me and out here everyone has little camaro z28's and ss's and since my truck is big they know i have a big motor but everytime i race them i lose. So I want to make a tall nice hot rod.
seawalkersee
Outside KCMO
Biggest cubes 460 v-8. Biggest block 6.8 L v-10. If you want to make your engine run, do a fuellie swap and put a huffer on it. Adding hp always makes all probles go away. Exe. Problem...These brakes ****. Solution...Add a hundred horsepower. Problem...My fenders are rusted through. Solution...Add a hundred horse power. See how much better it stops and looks?
Chris
seawalkersee
Outside KCMO
Ya know...supercharger, blower, huffer... The point was that you can build a 5.0 pretty cheep and then add like a powerdine or vortech for like 2grand more.
Chris
If money ever becomes not an issue theres a company called PAW www.pawengineparts.com I get alot of stuff from them there prices are really good but they have a 460 stroker motor that comes out to be a 521 Cubic inch they call it a 521 FORD DINOSAUR a long block kit cost $3595.00 says its for pro street,drags,marine,or truck puller . I think it would be alot of fun if you could keep axles under it . :D /emoticons/[email protected] 2x" width="20" height="20" />
king_butt_head
< seconds the paw catalog and the dinosaur and the alum 427 chevy oh s#@#$ i didnt just say chevy in a ford chat hey but they ALSO MAKE A 427 , 351W REPLACEMENT FOR 3K BOY'S YEEE HAAAWWWWWW :D /emoticons/[email protected] 2x" width="20" height="20" />
84broncorig
go wit a 390 they r hard to come buy but worth the money, i had one in a 7y8 f150 4x4 with locked front n rear n u couldn't beat it!!!
seawalkersee
Outside KCMO
390s are good stout engines. If you wanna go with an FE then you should go with the biggist cubes though. That would be a 428. The only problem then is the cost of hyperformance parts.
Chris
Bradt
Georgia
If you're looking to make a racer out of a Bronco, you'll probably end up with more problems than you're bargaining for. They weren't made to withstand the forces that a fast start exert on a 5000 lb brick. Be prepaired to destroy some axles, gears, and assorted other parts.
Other than that look for an engine that will get you what you need and has readily available parts/mods out there. A rare, high horsepower engine is great, but parts and mods can be prohibitively high. It may be advisable to go with a slightly lower hp motor just so you can get the performance parts, and keep it running, without breaking the bank.
brad
S
sreaminbronco
Dallas
Im not trying to make a race car out of the bronco but there are some offroad rally broncos racing the trails out there and i want to join the fun.
eholt80
