best suspension
71broncrollsport
im looking to get a full replacement suspension for my bronco, i need about a 3.5 in lift to run 33 or 35 inch tall tires. i am wondering if anyone has used any suspension kits from one of the many bronco aftermarket supliers. i was thinking of using duff front coils and leaf springs. i want a smooth ride over dessert wooops and the front to be a little higher than the back. the bottom line is what is the best combination of parts or kits. also what shocks?
Don't know where-u-are as you haven't filled in your info. pages yet.
Left or right coast EB suppliers will have all you need.
11 paks give the best all 'round ride & performance.
Best to get the complete kit fr. one store.
Keep in mind., the back will settle. Starting with the front high is not a good thing.
S_bolt19
Colorado
As long as you don't get a Rancho, SuperLift or Sky Jacker lift, you will be doing good from any of the vendors. I would say use either Duff, BC Broncos or Wild Horses. Doesn't matter what order, but those are the best companies to deal with. Cage used to have the best stuff, but they went out of business a year or so ago.
bigbluebronc
ca
Lockers and gearing will get you much farther down the trail then a lift and big tires, big tires need strong axle shafts ,too run fast you need big down articlualtion so run low and cut cut cut the wheelwells till they dont rub, the front fender well may need too be cut out too run the bumps, keep your bump stops in check so not too wreck shocks and such,,,,,,,,,, well shoot the wheel base on a bronco does not do well for desert bombing, buy a ranger or 4 link the rear and extend wheel base too at least 102, you have alot of work too do too go fast in an eb
BBB
fred tyler
