BigGreenBronco
I recently fixed my back window so that it would go up and down, but unfortanatly the switch does not work. I got a switch out of a bronco at a pick n pull and put it in but still it wont work from the dash or the key switch. I tested with the wires where they go into the tailgate(next tothe reverse light) and both purples wires have power. Then i ran jumper wires between there and the motor but still the switch will not move them. Just to make sure the switch works i tested the wires that come out of it and they have power when they are supposed to. The thing i noticed was neither purple wires have power next to the reverse light when i pressed up on the switch. Any ideas guys????? Is it possible i dont have enough power goin from the fuse to the motor to work it?
