AX-15 in a early Bronco?
cnotslar
Seattle Washington
Hey all,
New user for the most part here. I have a chance to buy an AX-15 5 speed for my 1967 Bronco. What I'm hopeing someone can help me with is.... I have a 289 out of a 67 mustang to rebuild and install in it and no transmission yet. I really would like to put a 5 speed in ( my wife really does not like to drive stick :-") If I can install this tranny in the Bronco, is there a bellhousing I can buy without having to use an adapter? or should I just buy the adapter and move the shifter hole further back? This is a work in progress, and would really appreciate any and all help I can get.
Thanks!
C
cnotslar
Seattle Washington
Talk to Advanced Adaptors.., they may have what you need.
Isn't that a Jeep I-4/I-6 trannie..? If you hop-up the 289 V8..., not sure that trannie is strong enough. :unsure:
Thanks, I'll give them a call and see what goes [-o< , I don't plan on building up the 289 much, maybe a bit past stock but not by far.
mikeiam82
Kelowna, BC. Canada
I just bought a bunch of parts from a guy locally he has a 302 efi from a mustang in his jeep and he uses it for snow wheeling up here in BC Canada. Long story short he had an ax-15 and he blew it up. it is the 4 and 6 cyl transmission for pre-2000 jeep wranglers. the post 2000 wrangler has the nv3550 trans which is pretty much just the beefed up ax-15. Its rated at 300 horsepower, that's what i'm putting in mine and what you should use if you're planning on running a stock type engine with around 300 hp or less. Any more hp you're better off going ZF, NV 4500, or the np435. This guy is building a beefed up auto to go in with a nitrous kit in his jeep so i scored all the manual parts super cheap. I bought the advance adapters kit for the swap, it is so simple to install all the parts with it and the drive-line length is only 1/4 inch shorter than stock so unless your lifting huge you don't need to change the drive shafts.
here is a pic i literally just finished putting my transmission on my engine
C
cnotslar
Seattle Washington
That looks so good! I wish I was to that point! I was looking at putting a NV3550 on mine but to find one is not cheap. I've found them on EBAY with the kits for around $2K with shipping and a warrenty.
mikeiam82
Kelowna, BC. Canada
I got my nv3550 from a guy who builds rock crawlers. it was in 1 of his jeeps he got and he didnt need it. stole it for $300 and then bought the advance adaptor kit.
C
cnotslar
Seattle Washington
I so wish I could stumble onto something like that! My budget is getting so low now that I might not be able to buy a vowel anymore!! I was looking on Craislist today and was contimplating getting a C-6. Someone has one for sale with the small block bellhousing for $150. not to far away from me. I was thinking that I could do that for now and when I get a couple credit cards paid off I could buy the NV3550 and swap it all out.
mikeiam82
Kelowna, BC. Canada
If your in the States your lucky, auto parts are soooooo cheap. In Canada lordco auto parts wants $407 for just a ring and pinion and that's with my 30% discount. Most parts if i buy from wildhorses or toms cause they are on the west coast are still cheaper with shipping and duties then if i buy local.
stevedave
