automatic 4wd
nicholas
i have a 95 ford bronco with automatic hubs and when i try to shift into 4 lo nothing happens. can anyone tell me what i have to do to fix the problem.
Did you follow the proceedure outlined on the back side of the driver sun visor?
I assume that it will shift in and out of 4 HI. Do you hear anything happen when you try to shift to 4 LO? Since you followed the procedure on the driver sun visor, I assume that you were in 4HI when you attempted to go to 4LO. There is a CB and fuse, fuse panel fuse 18 and a circuit breaker in position 12. I would check and replace them first if you don't hear anything.
N
nicholas
ok i checked the fuses and the buses and they are all fine what else could be the problem it shifts into 4 hi and when i press 4 lo in neutral i hear nothing. need help please
Lump1713
sometime when i try to shift into 4lo i sometimes have turn my truck off and restart it and then it will kick in to 4lo. dont know what cause that but i dont know prolly wont be using that alot anyway, really dont care for the 4lo either but you can try that maybe.
Coastersfwb
