auto to manual
demo42bboo
I have a 78 bronco with a C6 and a 351M. I got a donor trans from a 79 F350 2 wheel drive. I got the trans, bellhousing, clutch linkage, flywheel etc. Will the transfer case from the auto bolt up to that T18 or did they use a different transfer case for the manual transmission. I know I'm either gonna have to have driveshafts made or find another donor. Any help would be great. Thanks
Hi bboo., welcome..!!!
There may be someone on here that can help with that (not me)...
However, if you call or email Wildhorses &/or Toms br. parts, they can help.
It's more likely the adaptor & input/output shaft that's an issue.
They do these mods on a daily basis. They have new & used parts on hand.
http://www.tomsbroncoparts.com (lots of good used parts)
http://www.wildhorses4x4.com (EB store but also into '78-'79)
P.S. Be sure the flywheel has the correct # of teeth & correct balance.
jcm460
Most likely I would look for a 4 wheel drive trans or else your going to have to buy a adapter and change the rear shaft. I know when i went from a borg warner to a new process 4 speed I lucked out and everything bolted together and you might luck out on your drive shfts and not have to change them do to a c6 being a shorter style trans. :eek: /emoticons/[email protected] 2x" width="20" height="20" />
Bronco Paul
I did a swap to a T-19 but they were both 4wd trannys...the oddest thing I had to swap was the power brake booster...the manual setup required different mounting brackets!
Paul.
fred tyler
