auto fab wheel travel kits
ogre20012001
manti utah
I was wondering if any one has used the auto fab wheel travel kits and if you have are they worth the money that you spend on them thank you for your time
rubberdust
Henderson NV
YES! You'll be amazed
There's a big difference between their set up & a basic lift kit but unless you're gifted at fab work & lucky it's probably less expensive than what you can make yourself. It wont make your Bronco a Trophy Truck but they are durable really work well.
The only thing is do you have somewhere to go play that hard? if so yeeehaaaa!
motoxscott
You'd be surprised on how much a difference a kit by Autofab or Camburg is for the Bronco's. The quality and the type of parts you're getting is above and beyond what the typical lift kits give you. Really the only "lift kit" that is close is the **** Cepek stage 2 kit which I had on another bronco of mine years ago. Dont know if its still available though. The radius arms and brackets were built pretty well, but the problem lies with using drop down brackets for the i-beam housings and the shocks, etc.
- Scott
O
ogre20012001
manti utah
thanks for the information motoxscott do you have on of thies two systems on your bronco now? if you do how hard was the install?
Coastersfwb
