fordtruckman
- Joined
- Sep 10, 2005
- Messages
- 33
- Reaction score
- 0
351 400 alternator bracket installed picture. i need to confirm how mine goes back on. thank you.
Hey ford truckman, as i remember it... there should be a stud or '' pivot '' bolt on the top side of the alternator. I think that poivot bolt is located in the head or nearby the head with a pretty substantial lenght spacer. then there is the ''bananna'' tensioner bracket that should attatch through one of the water pump bolts also containing a spacer. ( much smaller than the pivot bolt spacer ) I will be back home in a few days when I can take a pic. and show you what I am seeing so you can finish the alternator install. I also believe that both bolts are 1/2'' sockets to set the bolts tight. you'll also need a pry bar or a sturdy small diameter pipe to apply the correct tension to the belt. you should have about 3/4'' of total play in the center of the belts longest span.I'll get back to you soon with pics..351 400 alternator bracket installed picture. i need to confirm how mine goes back on. thank you.
