Thanks,
David
That intake is designed for a EGR spacer plate. Intakes are usually designated EGR or Non-EGR. You could use an EGR spacer and block off the end of it where the EGR normally mounts with a fabricated steel plate, or mount an EGR with no control which would just leave you with a unused part hanging on the end of it.View attachment 2705View attachment 2704 I have a problem with my carb set up. I have an Ford alluminum intake part number RF-E4ZE-9425-GA and a holley 650 carb. I had to use a spacer plate to make room for the choke on the carb. The problem I have is that on that intake, there is a slot on the intake manifold right at the edge of the spacer plate. The spacer plate gasket covers it, but the spacer plate does not. I am getting a air leak at that point. Anybody have any idea which spacer plate I need to use??? Any help will be appreciated.
Thanks,
David
