Aftermarket steering column for 86 Ford bronco.
No juice
Washington
Hello, not sure I’m posting this in the right place.
I am looking for an aftermarket steering column that will work in my 86 Ford bronco with shift lever. I took out the four-speed manual transmission and putting in for 4R70W 4SP Auto.
I see a lot of aftermarket steering columns out there but i’d like to hear from somebody that may have actually installed one. I have looked for factory but haven’t found any that weren’t worn out, Thank you.
Motech
Santa Cruz, CA:
Your main obstacle is likely going to be compatibility as 4R70 series used a completely different column assembly that likely will not mount up without significant mods, AKA $$ and headaches.
You might be better off installing an aftermarket floor shifter.
stevedave
