90FordBronco
PO said it had an oil leak.......well it does, from about 14 different places. Amazing what you find when you work on someone else's truck. So I picked this beauty up for $600 and bought a gasket set and will be working on that today. During the removal of the engine i found: OOPS someone is missing 4 oil pan bolts, and look that exhaust manifold was repaired and cracked again, and either broken or lost bolts became a mix-match of bolts and washers for the water pump. Well regardless I'm in it for the long haul and will hopefully reap the rewards of driving this bad boy. Here's some pics of what I got done......oh oil was everywhere, so alil degreaser and a pressure washer helped.....
