95 bronco speaker blown out
sam2002
howdy
Anyone know the wiring codes for the speaker leads for a 1995 bronco?
right side door speaker crackles ,thought Id replace it ,removed door panel but the speaker isnt marked positive or negative
would like to know where to find info on this and all the speakers
thanks in advance for any help you can be
Sam
psychobiker
charlotte
why is it crackling..i have a 93 just replaced both rears.,..one connector is wider than the other it should be pretty simple..unless it is the wires themselves that need replacing
S
sam2002
The right front speaker was making the noise of a blown out speaker
The connector on the front speakers is a block connector (all one unit with both wires incorporated into it, it slides into place on the matching surface of the ford speaker. Black block about 1"x1"x1/4")
havent messed with the rear speakers yet but hopefully it is as you say with the seperate connectors for each lead
take care
uscdiver
San Diego, CA
Hello all,
I have a '94 and found this website with some good info about stereo wiring, etc. It let's you put in your make and model and gives you diagrams and insrtructions.
http://www.installdr.com/
Hope this helps!
Thanks, diver
Coastersfwb
