'95 Bronco Fuel Tank
AFDinMT
-Nevermind - Checked at Napa they had a $4 solution
Adam
I have a '95 Bronco with 351 and Fuel Injection, there is a single fuel pump in the tank. The fuel pump needs to be replaced. I've dropped the tank and disconnected everything except the two fuel lines going to the pump. These are a high pressure connection and I can't figure out how to get the couplings to release.
-Adam
406-642-9565
You need a special tool. You can get it from most any parts store, possibly even borrow it.
Pennsylvania
Yup, need a line tool. They make cheap plastic ring lookin things, but I could never get them to work well. Also make a ten dollar X shaped tool at harbor freight, but again I wasn't happy with how well it worked. Should be fine for you though. I went ahead and bought the 70dollar snap on set because I have lots of connections that I work with on the fleet.
Adrianspeeder
Coastersfwb
