92 Bronco Clutch problem
abmxz6
Morrisville, New York
hey guys, I just bought a new preloaded master cylinder for my bronco installed it and I still don't have a clutch. I tried bleeding the ***** and I didn't get any fluid coming out of the bleed, prior to putting in the new master, I had fluid in the ***** and it was bleeding fine. As of right now I don't have a clutch, im not sure where to go from here. if you have any ideas on what to do that would be great, ive tried almost everything but a vacuum pump. Im starting to think the ***** is shot too. I know the master was broke because I had fluid leaking in the cab, hence why I bought a new master.
Rons beast
Hey ab,
trying to bleed a clutch system by pumping is usually ineffective. The air just gets moved back and forth.  Try gravity bleeding first, then a few pumps should get some action from the ***** cylinder.
Using a vacuum at the ***** bleed valve should work too.
Good Luck
Sandoval_broncosauria
